Broken/Weak Valve Spring Symptoms
Old Aug 12, 2004 | 06:36 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
What are the symptoms of broken/weak valve springs?
I understand valve float at upper rpm for weak springs is common.
Would a broken spring cause the tune to go out the window, and would it necessarily have mechanical noise?
Old Aug 12, 2004 | 06:38 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You'd have issues with a broken valve spring...like a dropped valve into the chamber which would make a lot of noise.
What symptoms are you experiencing that give you the idea of a broken valve spring?
Old Aug 12, 2004 | 06:40 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, the last brokin valve spring I had caused a poping noise under hard acelleration.
Auggie
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Nick McCardle
Sep 10, 2015 08:36 PM
