Gasoline question
Old Aug 12, 2004 | 08:04 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Gasoline question
Yo guys, what brand of gas do you all use? Which brands suck and should be avoided? I've heard bad things about Arco and Exxon.
Thanks.
Old Aug 12, 2004 | 09:03 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I use the cheapo maverick gas at 87 octane on all the cars I have owned. it so far seems that msot all my cars run the same on just about any type of gas I get other then when I had my 71 camaro and had the timing bumped up a bit then I ran 91 octane
Old Aug 13, 2004 | 12:27 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
All gas comes from the same place, same pipeline, same same same. The only difference is the additives the specific companies add.
FWIW i normally don't use non-name brand gas.
Old Aug 13, 2004 | 01:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
ME Leigh hit it. Gasoline molecules are gasoline molecules. If they changed it per station, per company even, it would obviously no longer be gasoline.
It's the various additives that make the blend different.
I usually just end up going to whatever station I'm near at the moment when I need fuel. Usually a Shell, Speedway, BP or Marathon.
Old Aug 13, 2004 | 02:29 AM
Tremo's Avatar
OK, so if gas is gas, which company has the best additive package. Which sucks?
Old Aug 13, 2004 | 11:43 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
You might just want to try the different brands in your area for each different fillup. I just think gasoline a personal choice that only you can decide.
Old Aug 13, 2004 | 03:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
That is a question which is strictly open for opinionated answers. I doubt you will get any constructive answers that will truly help you. Try a bunch and form your own opinions.
Old Aug 13, 2004 | 08:34 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I am running Ethanol Plus in my Trans Am. Car seems to like it. For some reason 87 Octane causes my car to ping and run like crap. 89 octane and up seems ok.
Old Aug 13, 2004 | 11:12 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
FYI ethanol contains less energy then gasoline per volume. But it does have a higher octane rating and is highly subsidized.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Justin92GTA
Aug 27, 2015 11:16 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
