Cam Button bolts from Roller Block
Old Aug 13, 2004 | 07:19 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Hopefully someone can help me out here.
Anyway, I just got a roller block and I'm about to remove the old cam shaft. The sprocket and chain are off as well as the lifters. The cam button is the only thing left. There are two star bolts or (Torx which ever one) one either side of it. My question is does anyone know what size they are?
Also, I bought some grade 5 bolts to put the engine on the stand do you think those are good enough or should I go grade 8 ?
Brent
Old Aug 13, 2004 | 10:23 AM
ede's Avatar
ede
t30 i think but it's been a while. i only use gr8s even if all it does is hold the valve covers on.
Old Aug 13, 2004 | 10:30 AM
Car: 1986 Iroc
Engine: Afr 408
Thanks ede,
I'm about to head out to sears during lunch and pick it up. I have a T25 and it seems just a tad small, So I was guessing at 30 or 35.
Rats, I probably should have realized that as I was picking them up!
Thanks for your help.
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
LT1Formula
Aug 20, 2015 09:36 PM
anesthes
Aug 8, 2015 09:37 PM
