Car wont start
Old Aug 13, 2004 | 11:45 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Car wont start
Just suddenly today.
I drove it for a good 45 minutes, and while sitting in a parking lot when i came back it wouldnt start...
So i let it be for a bit and tried to start it and it started up fine...
so i go to another store park it... when i arrive back (10 min lateR) it wont start again...
i dont hear it crank, i dont hear any noises when i turn the key except for a relay in the lower left drivers side kick panel engaging. I am thinking it is either the relay or the ignition coil. Battery is good alternator is brand new.
305 TPI Msd Ignition Coil, new fuel pump, new IAC
Any ideas? Currently its in a best buy parking lot.... ill be going back out there within the hour....
Old Aug 13, 2004 | 11:49 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello HamSpiced,
The relay you hear in the kick panel is the starter enable relay. Have you looked at the ignition module. Good luck with it!!
Old Aug 13, 2004 | 12:01 PM
HamSpiced's Avatar
So... what your saying is.... it could be that relay??
wheres the ignition module... im sure at one point ive looked it it... but i just dont know what it is
Old Aug 13, 2004 | 12:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The ignition module is located in the distributor underneath the pick-up coil. The ignition coil has a two wire connector that plugs into it. If it goes bad, it often times will work when it is cool and fail when it is hot. This is often caused by not insulating the base of the module with that special grease that acts as a heat sink. You can get this module tested at most auto parts stores. BTW, when the car wouldn't start did the security light (VATS) stay on until you released the key?
Old Aug 13, 2004 | 12:39 PM
HamSpiced's Avatar
I honestly dont remember...
the car is currently at best buy chilling all locked up...
i think it may be the starter cause i heard no noises... so once i get it started... somehow ill try and diagnois it... till then im gonan try tappin the starter...
Old Aug 13, 2004 | 02:16 PM
HamSpiced's Avatar
got the car towed back home...
the security light dont come on, it doesnt crank..
I think the neg. wire got messed up cause its right under hte headers and the heat tubing melted to the wire... so ill start replacing things on my day off...
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
