Performance needed
Old Apr 28, 2001 | 05:01 PM
dkllw's Avatar
Performance needed
Im loooking to give my car a little extra power. im look to do several improvement so i guess where do i need to start at 91 camaro RS 305 auto i don't what my check engine light to come out so help me out.
Here are a few things i plan to do
1) Change aircleaner to open element (remove the factory set up.
2) tbi add a spacer and change jets.
3)add headers i like to stay in the $150-$200)which kind?
4)add a performance chip which kind guys?
5) also if i remove the crap on the passager side the air pump.
Will any of this give me a check engine light come on.
Please guys need some input only have about 400 dollars to spend.
dave
Old Apr 28, 2001 | 06:39 PM
SUPER-SPORT-CHEVY's Avatar
Check engine light, probably code 32 egr BS!
400$ is kinda a tight budget unless you can do the work yourself. I would say get the headdres "any kind that fit" that will probably take you budget down quite a bit.
I would recomend instead of the stuff you posted get a nice crane compucam with more duration than stock.
As far as emmisions crap goes if you can cut the cat off go for it that will increase you power. the smog pump will not through a code as long as you dont get to carred away with wire hacking.
Good luck!
SSC
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
