HELP ---> Did '86 TAs have the "peanut cam" ???
Old Apr 28, 2001 | 02:52 PM
maksik7's Avatar
I'm about to go looka t an '86 Trans Am, and I just read that that year TAs came with the "peanut cam" which reduced the HP to 190. Is this true, will I get 20 HP's if I replace the cams? Also is there any Torque loss from these peanut cams?
If I do decide to replace the cams, how much will it cost for a quality set of cams??
Thx for all your help
-Max
Old Apr 28, 2001 | 03:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
86 TPI engines have the small cam, yes.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 28, 2001 | 06:46 PM
Guest
Guest
Posts: n/a
I doubt if you will get 20hp by replacing the cam with any other stock cam. And there is only one cam in the engine FYI. Its quite a job to change, so if you are looking for something quick that you dont have to put a bunch of effort into right away, I would suggest a 350.
kane91z
Jan 5, 2003 08:39 AM
Sitting Bull
Jul 12, 2001 11:02 AM
Apone
Jun 13, 2001 02:25 PM
new87
Apr 1, 2001 12:31 PM
new87
Dec 31, 2000 07:16 PM
