Cam in, disipointing at the track.
Old Mar 31, 2001 | 07:12 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I changed the peanut cam in my 87, to an LT-1 cam 418/430, 194/199, lsa 111. I also ported the plenum, runners, and base; and installed an air foil and AFPR. Last year with only a cat back I ran a 15.4 at 87.5 mph, today I ran a 15.0 at 89.5 mph. I had a net gain of 19 hp is this normal? I figured at lest a 1/2 sec gain. anyone else got any proven number gains with a cam change?
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, rapid fires, and 170* Stat.
Old Best 15.414 @ 87.47.
“Fallen But Not Forgotten”
Old Mar 31, 2001 | 07:58 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
My sob story:
305 with peanut cam: 14.5 @ 96mph
305 with SLP .480 .487 lift 206 212 dur: 14.6 @95mph
If I'd wanted to go slower I would have pulled off a plug wire or something. I coulda done that for free.
Old Mar 31, 2001 | 09:51 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Find a scanner and record some data from your runs down the track. You have to tune computer cars also, but you don't know what they are doing unless you record some data.
Try adjusting the initial timing and fuel pressure, that should help.
Old Apr 1, 2001 | 08:51 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You were expecting 1/2 a second, well .4 is almost .5, but I get your point.
You said you installed an AFPR, what did you set it at? If you didn't make any adjustments, the pressure may be too low, and if you cranked down on it alot, you are probably choking it out w/ too much fuel.
Are you haveing traction problems?
Also, I see that your only exhaust mod, is the Catback. If you still have stock manifolds, then you are probably trying to pump in more air than you can get rid of. Get some headers, and and a better flowing catalyst, and you should net some better gains.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 1, 2001 | 12:31 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Yes I made adjustments after every run. I tried fuel persures from 42 to 50. I adjusted timing from 2* BTDC to 10* BTDC. Best run was made with INT settings of 8* BTDC and fuel presure of 42psi. Buy the way it was the first run of the day. Just for info I ran 15.1's all day @ 89- 89.5 mph. My 60' times were 2.18 all day with the best 2.16 on my best run.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
