Car won't start - wiring issue??
Old Aug 15, 2004 | 12:04 PM
'89 superbird's Avatar
Hi all,
Just finished swapping back in my tpi intake so I can sell my car(don't worry I bought another one)
Trying to start it and it turns over strong but never catches. I thought it was distributor so I pulled plug 1 and adjusted to TDC. Not the issue. Some funny things have occurred, first, my front markers and signal lights aren't working and it is not a fuse. Second, when I crank the car, the power door lock actuators open/close repeatedly.
Any ideas??
thanks
Old Aug 15, 2004 | 12:35 PM
Vader's Avatar
The lighting problem may be a ground, connection at the starter, or fusible link. The connector at the firewall for fusible link power distribution is always suspect.
The door lock operation is a mystery, but the solution to the lighting problem may also solve that gremlin.
Old Aug 16, 2004 | 06:57 AM
Thanks Vader,
Where and what does this fusible link look like. It sounds like it might be the beast as I have an alarm in the car and when doors are locked or unlocked the markers should go on. Since I am having issues with both things, it could solve both problems.
thanks
Scott
Old Aug 17, 2004 | 08:01 PM
The distributor seems to be the issue. When I took the plug out of #1 and bumped it until I felt compression and then tried to put it in, it just doesn't go in with the rotor pointed at #1. It will go in with it pointed to #6. Took valve cover off to confirm that it should be pointed at #1 and confirmed the issue. Any suggestions. I could just wire it with #1 where 6 should be and so but doesn't seem like best solution.
Old Aug 17, 2004 | 08:11 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Wouldnt that mean its 180*out? Just flip the rotor. Im not sure, but that seems possible...
Old Aug 17, 2004 | 08:16 PM
88fbird's Avatar
Car: 84 S-10:(
You will have to turn the Dist. 180*, or just plug the #1 plug wire where the rotor is pointing on the cap. Then follow the firing order around, IF your wires are long enough.
Old Aug 17, 2004 | 08:17 PM
88fbird's Avatar
Car: 84 S-10:(
Oh yeah, the rotor will only go on one position.
FBird
midge54
Dec 27, 2019 04:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
