Please help, my car won't start.
Old Aug 15, 2004 | 12:37 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
I tried to start it and I got nothing, the starter doesn't turn, the fuel pump wasn't engaging, the lights won't work, nothing. I thought maybe it was the battery, so I replaced it, nothing has changed. I turn the key and absolutely nothing happens. The only thing it does it when the key is in the ignition the buzzer sounds, but it sounds really weak. Anyone know what could be wrong, thanks.
Old Aug 15, 2004 | 03:43 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
How much voltage are you getting to the starter when you are tryinig to crank it? You may have a bad battery cable.
Old Aug 15, 2004 | 03:48 PM
ljnowell's Avatar
bad ground?
Old Aug 15, 2004 | 10:05 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Turns out it was a bad battery cable. Thanks for the help guys.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
86Base
Aug 8, 2015 01:34 PM
