engine died at a trffic light
Old Aug 15, 2004 | 06:13 PM
springfield's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 tbi
Transmission: 700-r4
a ouple days ago i was sitting at a traffic light and when it went green i hit the gas and nothin happen, so i turned down the music and my engine was off, so i turned the ignition off and tried starting it. it started up but it was stumbling and sputtering so i shut it off and then it wouldn't start after that. i assumed i was out of gas so a bypasser threw 5 bucks in and it still wouldn't start. eventually the bypasser told me to run it threw the gears and then try starting it and it started right up and has run fine since.i checked when i got home for a leak of some sort because the day before i had just put 30 bucks in and hadn't driven much and i couldn't find one. so i'm wondering if i was actually out of gas or if something else went wrong. if i was actually out of gas i assume that somebody sifined(not sure on the spelling) my gas out of the tank. my gas guage also said the tank was full but i think it's broken because it still says full. so if anybody has any ideas of what else could be wrong or how much it would be to fix etc. that would be greatly appreciated. thanks
Old Aug 15, 2004 | 06:48 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Punctuation and paragraphs would be nice.
Have you tried filling the tank yet?
Old Aug 15, 2004 | 06:53 PM
Engine: 305 tbi
I havn't tried filling it all the way cause i don't have cash at the moment but i did put about 5-10 bucks in that i had in a the garage at home.
Old Aug 28, 2004 | 09:55 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
have you ever changed the fuel filter on it ??? could be as simple as a plugged filter causing the problem with it dieing ..
have you seen any wet spots under the car or smelled gasoline when your around or in the car at all ??
does it start just fine now ?
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
