switchin stock fuel pump to Holley fuel pump
Old Aug 16, 2004 | 07:47 PM
daddy33's Avatar
Car: '85 Camaro
ok im a little confused, i put a new Holley fuel pump (110gph) and noticed that it has two connections which im sure is the fuel input and output but as for the stock fuel pump there are THREE not two connections. What exactly does the other one do? Im trying to figure it out. I looked in my manual but dont see anything on it. Do you guys know where it goes?
Attached Thumbnails switchin stock fuel pump to Holley fuel pump-oldfuelpump.jpg
Old Aug 16, 2004 | 07:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 3rd one is a return line back to the tank.
It's a very good idea to keep it. Instead of dead-heading the fuel when pressure is high enough, it returns the excess back to the tank. This has the effect of keeping cooler fuel going to the carb.
Unless you have a mongo engine, a stock replacement fuel pump will keep up with the demand. My original pump (at least the one that was on the engine when I got the donor car) was shot, but the AC replacement I got from Checker (Kragen in your neck of the woods) has performed just fine for 5 years.
Old Aug 16, 2004 | 10:21 PM
daddy33's Avatar
Car: '85 Camaro
well the engine going in is kinda big and i know its going to be thirsty for fuel. I would like to keep it if it has the effect of keeping cooler fuel going to the carb, but since my holley FP doesnt have that extra 3rd connection, would it be ok to not have it? In other words block it off some how.
Old Aug 16, 2004 | 11:32 PM
five7kid's Avatar
Okay, I'm supporting about 325 gross horse. That'll probably increase by about 50 in the near future, and I've got no qualms about keeping the stock-type pump. RB tells of supporting a nice-running 400 with a stock type pump. If you listen long enough, he'll even tell you that a light-weight pushrod will help more than a "bigger" fuel pump like a Holley.
The benefits you'd be sacrificing will most likely outweigh the benefits you'd gain with the non-return Holley. I'd return it.
But, if you really want to keep the Holley, block off the un-used return line.
Or, get a return-type regulator and connect the return line to it.
92camaroJoe
Jul 29, 2023 07:57 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
