Quick Question
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Quick Question
Alright guys as most of you know i just got done swapping in a mild carbed 350 into my camaro and have had a few difficulties. Well I have noticed that the temp. is getting a little higher than in did in my old 350 tbi. So I started looking over the cooling system with a friend of mine( he has owned many 3rd gens so I thought he would be of some help). And he said that I dont need the hose that comes off the intake manifold and runs back to the radiator(not the main upper rad hose). I thought that it was some type of return hose and that it was needed so I kept it, but he tells me that its only for the heater and I dont need it now that i dont have one, and its only pumping hot coolant back into my radiator therefore increasing my temp a little. So what do You guys think of this. And just FYI I have a performer RPM intake and I just have the hose running straight to the radiator not to the firewall or anything else. Thanks for your help.
Transmission: 4L80E/4L80E
If it's not going through the heater core, you don't need it.
Car: 89 Camaro RS
Cool, thanks. But do you think that since I do have it that it may be making the temp go up or would there not be a difference?
There is probably some effect. Hard to say how much, though.
Block it off and see how it does.
