LB9 vibrating when releasing clutch slowly. WHY?
Old Apr 30, 2001 | 12:48 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Every third gen that I have owed with a manual tranny (3 of them) have developed a vibration when I would release the clutch on the first gear ONLY. Most of the time it happens when the car gets warm and it vibrates more when starting driving up the hill.
Does anybody else has these problems?
PS. I keep my foot OFF the clutch when stopped at the red light.
Any ideas?
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old Apr 30, 2001 | 09:25 AM
84TransAm's Avatar
Happened to me too. Resurfacing the flywheel was the answer for me.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance Soon: Edlebrock Intake & TES
Old Apr 30, 2001 | 09:46 AM
Steve89GTA's Avatar
Resurface the flywheel and drop in a new clutch. Also, if the problem get worse as the car warms up, you could be getting an oil leak the dripping into your clutch assembly causing the 'chatter'.
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
