1.6 ratio Roller Rocker Help
Old Apr 29, 2001 | 05:34 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I am going with 1.6 Roller Rocker's for my L98 with SR Torquer heads. I have been told I need to get new pushrods when I do the rocker upgrade. Anyone know if I need different length pushrods?
Fredzep
90 GTA 350 5Spd
TPIS, SLP, Borla, K&N Mods
Old Apr 29, 2001 | 05:35 PM
ede's Avatar
ede
if the rockers is all you change no you don't.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 29, 2001 | 10:54 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
Thats what i thought. And yeah I am only replacing the rocker arm. Thanks!
Fredzep
90 GTA 350 5Spd
Old Apr 30, 2001 | 10:21 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
1.6 rockers arms are a tight fit with World
S/R Torquers. I tried a fitting on my new motor with 1.6 Comp Cams roller tip rockers off my old motor and there looks like there is interference between the head guide hole and the pushrod.
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old Apr 30, 2001 | 02:44 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I am using the 1.6's on the Torquer heads for the 350 which has 76CC. Do you think that would make a difference? Are you using the Torquer 305's?
Fredzep
90 GTA 350 5Spd
Old Apr 30, 2001 | 03:32 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I am using the same Torquers as you but with
67 cc chambers on a new 350ci/366hp crate motor that is not installed yet. I also
saw some posts on this board that stated you
couldn't use 1.6 's with World S/R series heads wihout modificaton.
Tom K.
Old Apr 30, 2001 | 05:27 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I am doing the swap tomorrow and will let you know how it turns out. BTW, I am using Summit 1.6 Stamped for $69.00.
Fredzep
90 GTA 350 5Spd
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
