How do i know which timing chain/gear set will fit my 1986 IROC?
Old Apr 30, 2001 | 09:04 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey all. I ordered a timing chain and gear set from summits webpage yesterday.
It is a "Comp Cams" set, the dual chain or "true roller" version.
On summits webpage, they said it would fit all small block chevys from the years 1955-1991. 305's included. I figured i had selected the correct chain with the information the provided on their site.
When i checked my summit magazine at home however, this same chain set had a foot note that they didn't have on the webpage. it said "will not work with factory roller cam"
Well, i do have a 1986 IROC 305 TPI "LB9", but i am not sure if this set will work or not without a cam change. Does anyone here know?
I am having the chain itself installed for 300 bucks, and don't have several grand lying around to pay for the installation of a new cam, so picking up a new cam and changing the old one out is out of the question for me right now.
Just want to double check with everyone here to make sure i ordered the correct chain set for my car.
Thanks for the read! please reply
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Old Apr 30, 2001 | 09:14 PM
Guest
Guest
Posts: n/a
Well, you dont have a roller cam so you should be ok. Whats the part number you ordered?
Old Apr 30, 2001 | 09:19 PM
Christos's Avatar
CCA-3100 is the part number. Thanks!
Old Apr 30, 2001 | 09:32 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
not sure what the problem is. an 86 LB9 didn't have a roller cam.
Old Apr 30, 2001 | 09:38 PM
Christos's Avatar
Cool. I assumed that a "roller cam" was a "non hydraulic cam". (im pretty sure i have a non hydraulic cam stock, but im not positive)
Im still not too familiar with what's what in a engine. Im working on it though.
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Why don't they work with the roller cam? Pardon my ignorance here if it is something simple and obvious!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 30, 2001 | 10:22 PM
Guest
Guest
Posts: n/a
The cam gear is different on the roller cam engines due to the retainer plate.
CCA-3100... thats what you need. You're all set.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Frozer!!!
Jan 19, 2024 04:55 PM
kah992
Aug 19, 2015 02:55 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
