mini starter questions
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
After recently fighting starter heat soak problems, I have done numerous searches on this board and become very educated in all areas about heat soak, heat shields, remote solonoids, starters, mini starters, ETC, ETC, ETC.
Knowing that I pretty much need to go to a mini-starter when I switch from the Hooker shorties to the Hooker long tube (near future) and having read many posts about using the LT-1 style starters instead of an after market starter such as the CVR, Summit ETC, my question is:
Which is a better starter or a better choice?
the LT-1 like the one I might get from a parts house or
http://www.turbobuicks.com/lt1starter.html
OR
an aftermarket such as the CVR, Summit, Jeg's, ETC.?
Also, would a heat shield be necessary/advisable with whatever version of a mini starter I end up with?
Thanks in advance for any help!
Craig
OR
Craig
Car: 1989 IROC Z-28
Couple more questions I thought of:
I remember reading in a couple posts here on third gen to stay away from the Hitachi style (why?) and that the Nippendenso style was better (why?). Is there any easy to tell the difference between the two?
Was looking at some mini starters on E-bay. Any opinions on which would be the better choice?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
http://cgi.ebay.com/ebaymotors/ws/eB...category=46098
http://cgi.ebay.com/ebaymotors/ws/eB...category=33576
Thanks again!
Thanks again!
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i've used #3 on your list for almost 6 years now with no problems. mine is for the 168 flywheel. i use the mini starter , heat shield and remote solenoid. it clears the 3 sets of headers i've tried
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I remember having Pep Boys look up a LT1 starter for me and they quoted over $200. My CVR pro-torque mini starter cost like $150 and works/fits good. I can start my motor with 32* initial timing so I'd say its pretty tuff.
Car: 1989 IROC Z-28
Just out of curosity--why the remote solonoid?
Did U still have heat soak problem with this starter?
Long tube or shorties?
mhatfield 14
Oct 24, 2015 07:48 AM
Dialed_In
Aug 20, 2015 01:45 PM
