rear end swap q's- please help !!
Old Apr 30, 2001 | 05:00 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
ok, here is what i am PLANNIN on doing:
i want to upgrade to 28 spline axels, can get the posi cheap from slp, 75 bucks. ok, i have an 86, with the 26 spline axels...
what size gears should i use? doesnt one have a bigger pinion bearing that wont fit my case? just curious if this is an issue...
should i go with the original size which is 7 1/2 or switch to 7 5/8 gears?
thanx guys- this was just brought to my attention and i want to solve this before i get stuck with something!
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, 1 inch carb spacer, Fiberglass cowl induction hood, Formula wheels, vette servo.
Current Plans: Waiting on: rear end parts- upgrading to 373's, 28 spline axels, slp zexel torsion posi, and a disk brake setup. Also have lowering springs, front struts, and hopefully a new mild 350.
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Apr 30, 2001 | 09:46 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the gears interchange, but your's should have the 7 5/8.
Old Apr 30, 2001 | 10:08 PM
89ROC's Avatar
Get that Torsen posi from SLP, then go to the junkyard and get 28-spline axles from an 88-92 F-body. The gears and bearings are all interchangeable between different years (except for the BW 9-bolt rear end). You should have 7 5/8 now. IIRC you CAN'T get aftermarket 7 1/2", I think they are all 7 5/8 no mnatter what. I highly recommend Motive gears. I've set up a few sets before, and NEVER heard noise from them.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
Old Apr 30, 2001 | 10:45 PM
fb305svs's Avatar
Thanx a bunch guys- i was definately not sure on the gears... i know richmond sells em in both sizes, believe it or not.
Motive gears huh? guess i will definately check them out!
Steve
Old May 1, 2001 | 01:08 AM
jaretz28's Avatar
Hey, this is a good question. But all I want to know is what knid of posi are you getting for 75 bucks? Can't be very good can't it? Do you know there website? Can anyone get one or do you have "connections?" Thanks
I believe that they changed from a 10 bolt 7.5 to 7 5/8 inch in 1988. This is also when they decided that 26 splines were out and 28's were now standard in Camaros and Firebirds. The gears are all interchangable from 1982 to 1992 Camaros, some Astro Vans and Monte Carlos. There are a few others like S10's and Blazer's but the years of the vehicles escapes me right now.
Old May 1, 2001 | 08:51 AM
fb305svs's Avatar
Jaretz- its an slp one, its just an oem posi from the 4th gens.... which were stronger than the others...
Steve
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
