CTS
Old Apr 27, 2001 | 03:42 PM
Steve89GTA's Avatar
CTS
Coolant Temperature switch? Where is this located? Could this be causing my stumbling issues?
Old Apr 27, 2001 | 04:44 PM
irocbsa's Avatar
If you are talking about the fan switch then it is between the #6 and #8 spark plugs on the passengers side head.
If you are talking about the gauge sending unit then it is between the #1 and #3 spark plugs on the drivers side of the block.
If you are talking about the coolant temperature sensor then the CTS is located on the front of the manifold near a hose fitting. Anything else would probably not give you stumbling problems. It has two wires going to it: 1 yellow and one black. Yes, it could most definitely cause your stumbling problem. Are you getting a check engine light. I chased a persistent CTS problem for about a year. The car generally ran like ****, real rich. I ended up replacing the switch and the wiring all the way back to the ECM. If you have questions or need a trouble shooting procedure,email me at irocbsa@mindspring.com. Good luck.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
[This message has been edited by irocbsa (edited April 27, 2001).]
Old Apr 30, 2001 | 08:37 AM
Steve89GTA's Avatar
Nope, I'm not getting any SES lights but the CTS is what I'm looking at to replace. I guess it's the one located just above the waterpump housing near the manifold correct? Are they expensive? Wouldn't it throw a code if it was bad? The stumble is in the low RPM only.
THanks again.
Old Apr 30, 2001 | 10:01 AM
rondubbs's Avatar
yes it could throw a code 15 if it were bad, they are about 15$ and easy to replace.
Old May 1, 2001 | 09:20 AM
Steve89GTA's Avatar
Beautiful!, then I'll replace this first and see what happens.
Thanks.
Old Oct 10, 2004 | 04:24 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Sorry to bring this one back from the dead, but did this solve your problem?
specialized
Jun 18, 2022 09:26 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
GTAman
Sep 21, 2015 09:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
