Voltage Meter Drops!!
Old May 1, 2001 | 01:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
When my headlights are on and I turn the wheel, my volt meter drops below 13 and I hear a squeeling sound. I replaced my belt that goes around the water pump, crank and power steering and when I did the car started charging right away. The old belt had a couple missing teeth on it, that belt was fairly new. Now it appears that this belt might be going bad now because it's not charging that well at times. But this mainly occurs when I have my lights on and turn the wheel. Could this all be do to the fact the pulleys aren't aligned right. From what I can tell they are aligned right, but could a small misalignment cause a squeel at times.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old May 1, 2001 | 01:55 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Belt squeal is generally due to loose belts... Seems reasonable. If your voltage drops below 13 at idle, don't be too surprised, with the headlights on, at idle, my volt gage will generally sit around 12.5... The electrical systems in these cars were not the best.....
Old May 1, 2001 | 02:44 PM
Steve89GTA's Avatar
I had a similar problem and my bearing in the alternator was shot...
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
