Lifter retainer? Do you need it?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What does it do? And why do we need it? One came on my ZZ4 motor. Now I added something and am having some interference problems.
What will happen if I take it out? Will it hurt anything?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You need it. It keeps the roller bearing squared on the cam so they roll on the cam lobe. Thats how the friction is reduced. Leave the dog bones in there.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Originally posted by Stekman
What are these interferances issues?
Engine: 355
Axle/Gears: 4.11
My direct port 200-600hp kit.
One of the tubes is hitting the hold down bolts. I already bent one of the lines, but now another one is hitting the front bolt that holds the little spring retain down. Which holds the dog bones in place. Maybe I can get way w/ running only 2 of those 3 bolts.
But that doesn't sound good.
Car: 1991 Camaro Z28
If it comes down to it you can always go with aftermarket lifters. They use a different method to hold themselves that doesn't require the sheet metal spider.
Car: 1989 Trans Am
Engine: 355 HSR
Hmmmm.... direct port... hmmmmm
Yeah I could see how that would be an issue... you can't bend the tube around that bolt a little?
Engine: 355
Axle/Gears: 4.11
yes drect port, jetted for 300, and run w/ a separate fuel system and a progressive controller. Should go low 10's. I'm hoping. If not, I'm selling the car. And I'm serious about that.
I could, but I've already spent lots of hours bending them the way they are. It's been the biggest PITA so far. I need to get some pictures.
Do you know who makes those lifters? Right now I don't know if mine are special or not. I just bought the ones summit suggested for my cam. cc306.
Car: 4
Engine: 6
Transmission: 5
Everybody that makes roller cams, makes (or sells) the original design roller lifters as well. Comp, Crane, Lunati, Isky, etc. etc. etc. Comp's part # is 853 IIRC (that would be 853-16 for a full set for a V8) and yes they are not cheap. Or inexpensive either. But that system is a whole lot more sensible than the factory's bizarre Frankenstein setup.
Engine: 355
Axle/Gears: 4.11
Thanks for the info. I've only redid 2 lines and it seems to fit a lot better. Now I just need to clearance the main feed lines.
Car: `86 SS / `87 SS
skinny z
Oct 5, 2015 06:23 PM
dimented24x7
Sep 6, 2015 03:51 PM
