what is the temp rating for the permatex high temp coper sealent?
Old May 1, 2001 | 06:42 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
The tube I seen said high temp copper selant, 750 deg? is that high enough for the header gaskets? The kind I seen was not permatex though.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old May 1, 2001 | 08:34 PM
ede's Avatar
ede
you don't use, or need, sealer on header gaskets. the ultracopper is soem good stuff, i use to use it for head gaskets on my kart engines, nothing but ultracopper, no gasket.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
b4ccamaro
Jun 5, 2016 01:48 PM
corey8084
Sep 17, 2015 02:56 PM
DARKmj16
Sep 9, 2015 04:07 PM
hdis2002
Sep 8, 2015 02:52 PM
