Front Seal
Old Aug 24, 2004 | 03:46 AM
klystron's Avatar
Car: 87 IROC
Engine: 350cu.
Transmission: 700-R4
Front Seal
Can the front crankshaft seal be replaced with out removing the
timing chain cover? Has anyone done it and is it just a matter of removing the crankshaft pully and harmonic damper?
Old Aug 24, 2004 | 04:55 AM
ede's Avatar
ede
sure it can, yes remove dampner and pulley
Old Aug 24, 2004 | 09:53 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Ede is right... just take off the balancer and pulley... then pop out the old seal and press in a new one.
Old Aug 24, 2004 | 10:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Grease the outer part of the damper hub (the side that will come in contact with the seal) before final assembly.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
