im going crazy
im going crazy
well i have a 305 tbi. and i dont like it. Now i was thinking about going to a carb. but thing i heard that the tpi system is a good one too. I think they make just about the same HP. and carb is easier. so what do you think carb or tpi? and i was wondering if some one knows a link to doing a tbi to carb swap? thanks
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I say go carb. The TPI swap is much more costly and a bigger PITA. The swap is really easy I did the whole thing in less than a day. Heres the link, feel free to ask any questions.https://www.thirdgen.org/newdesign/tech/carbswap.shtml
Transmission: 4L80E/4L80E
TBI -> carb will not be emissions legal. Is that a problem for you?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
TPI makes really good low end torque but leaves a lot to be desired as far as hp is concerned. If you took 2 engines setup the same the one with the carb would make a lot more hp then the tpi one would. Tpi is also very limited as far as rpms are concerned where as a properly setup carb isn't. If your shooting for proformance carb is the obvious choice, tpi will most likely get better gas mileage though.
Pac J
May 17, 2020 10:44 AM
Stay with your TBI, see link SPO Technology Central, IMHO.
