Could I make 530hp do 9.75secs in the 1/4?
Old Apr 30, 2001 | 09:06 PM
LottaBallsCamaro's Avatar
I mean with every sort of upgrade. I just saw a magazine with a (gag)civic doing high 9's with 530hp@9300 RPM.
Old Apr 30, 2001 | 09:13 PM
Guest
Guest
Posts: n/a
Sure, just make sure to put the engine in a Civic
Old Apr 30, 2001 | 09:51 PM
dtpmike's Avatar
of course...if a civic can so it an engine that is over 2 times as big.
Old Apr 30, 2001 | 11:06 PM
KW87GTA's Avatar
The civic weighs a hell of a lot less than our cars do. 530hp should get you into the 11's. Where depends on how well you hook up and shift. Good luck.
Old May 1, 2001 | 12:44 AM
Yarnboy's Avatar
Sure! You just need a 6500 stall converter, through an 8 speed and 6.73 gears and tank tracks!
  • Red '88 IROC 5 Speed 305 TPI w/3.08
  • Dual Friction Stage III Centerforce Clutch
  • Accel 300+ Racing Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Hypertech Chip
  • Hypertech Airfoil
  • Gutted Air Box
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old May 1, 2001 | 12:58 AM
jaretz28's Avatar
Why not go for a cool 1000 Hp. Just round it off to the nearest 1000 ! Try that and tell me you don't bash that 9 second mark.
Old May 1, 2001 | 01:38 AM
mtx28's Avatar
yea.. i mean hell, while your at it, throwing every mod possible, just toss on some sort of crazy fuel system and a 500hp fogger nitro system. now, given you've already put the tank tracks on it, you theoretically should be able to hook it up.. if not, i guess its your driving skills that are lacking. seriously, are you really going to try to do this? it doesnt seem like you are, more or less just curious. yes, people have done it, and yea, money(other than skill of doing the work) is going to be the only thing that holds you back. i hope this isnt another one of those 'i want a street drivable 9sec car' posts..(anyone else remember that one?)
oh yea, 530hp isnt gonna touch nines--cant say this from experience, but from all the cars i've seen, its not gonna happen(thinking of a blown GNX right now, runs 9.5's before tweaking, and had about 950hp)
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
[This message has been edited by mtx28 (edited April 30, 2001).]
Old May 1, 2001 | 08:21 AM
Mark W. Winning's Avatar
I am at about 525 hp with a 3,100 lbs chassis weight. It puts me right about 11:20's on a good night. I 100 shot on top of that puts me at 10:60's, but gearing becomes an issue for me. So, no you will not see the 9's.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old May 1, 2001 | 08:59 AM
Steve89GTA's Avatar
A little off topic, but at St. Thomas Dragway in London Ont I saw a Mustang run a 7.56 from J&P Performance. The only thing I could see on the outside was a massive hole in the front fender towards the passenger side for a big *** turbo I guess. The wheelie bars were scraping the whole way down...wicked.
How much HP do you need for 7.56??
Old May 1, 2001 | 10:57 AM
jaretz28's Avatar
My guess is that sucker was turboed if not twin turboed then fogged like hell with NOS.
I think in a mustang probably 1500 - 1600 HP
Old May 1, 2001 | 11:02 AM
jaretz28's Avatar
What luck, some mainiac was just at Walmart when I was there showing off this time slip yesterday. He runs a 9.69 in the 1/4 mile. He drove this baby all the way down our main strip in broad daylight and it got license plates. A true 9 sec. daily driver. Over winter I forgot how big 33 inch wide mickey's really are! By the way, the car is an '88 Monte Carlo SS.
Old May 1, 2001 | 02:37 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
If you get your race weight around 2000 lbs, then 530 hp might get you to 9's. I'd hate to say it but the honda's are catching up. My friend ran 14.7 at 94 in his $6000 civic, stock Interga GSR engine in a light civic. Kinda scary that with a stock engine from a different car, civic's can run with stock V8s.
Old May 1, 2001 | 09:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 3000+ pound car needs about 800HP to get into the 9's but then you also need to be able to get that power to the ground.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 1, 2001 | 09:54 PM
No, I'm not gonna do it, but I was just curious...
Old May 1, 2001 | 10:05 PM
302GT_killer's Avatar
youll need roughly 750 hp and a high operating range. 530 should put you in the low 11's if you can hook. the civic could do that since its half our weight and has a smaller parasitic loss
Old May 2, 2001 | 01:04 AM
jaretz28's Avatar
Don't care how fast those civics or imports go. They all sound like hair dryers to me !
Old May 2, 2001 | 01:35 AM
burnoutrpm's Avatar
yeah i saw that civic it ahs like abillon poounds of boost!! just forget it normally asperated!!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old May 2, 2001 | 01:01 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i think stephen is running at 10K feet altitude again. According to the standard 1/4 mile formula ((1/4 speed * .00426)3)/weight), you can get 135 mph (about 9.9) with 5 lbs per horsepower. Or about 600 hp with 3000lbs.
Old May 2, 2001 | 08:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I'm always racing at altitude. That's the trouble when you live near the rocky mountains. Some day I'll go to a race at sea level just to see how good it really is.
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
tricky1
Aug 23, 2015 01:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
