Weird noise
Old Aug 26, 2004 | 03:40 PM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
Weird noise
The motor is a high mileage freshly rebuilt 350 out of a 90 1/2 ton pick-up.
We installed it after replacing the rings ,bearings, oil pump, cam and lifters, and having hte heads freshened. We put the stock 86 TPI equipment on it and has ran like a charm for a while. The motor has excellent oil pressure and compression check shows 110 psi average (the lowest being 102 psi).
Lately we noticed a weird noise it was making wether in or out of gear. When you stop the gas suddenly it gives an audible double knock. At first I thought a rod bearing or wrist pin, but after messing with it and looking it over I am stumped. the oil pressure remains rock solid, and if I bring the rpms up slowly no noise is present. I put the car on jackstands and had a freind work the throttle from above, the noise is in the very back 6 inches of the motor towards the bottom.
Car still has plenty of power.
Any ideas?
Old Aug 26, 2004 | 04:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
flex plate
Old Aug 26, 2004 | 04:21 PM
Car: 97 WS6 T/A
Engine: LT1 383
What do you think it could be hitting on? Starter?
Old Aug 26, 2004 | 05:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
it's cracked around the crank bolts
Old Aug 27, 2004 | 01:11 AM
Car: 97 WS6 T/A
Engine: LT1 383
Ok, thanks, I'll take a look.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
