L98 Heads
Old May 2, 2001 | 08:04 PM
82resto's Avatar
L98 Heads
Anyone have advice on putting L98 heads on an LG4 305? No emissions need be passed, and I would love to put a set on, since I can get them at a good deal through one of my friend's dads. What work would be necessary to make them work with my 305? I don't have many tools, so I would have to send them to a machine shop...
Jon
82 Trans Am
Original 134,000 mile LG4
Holley 600 cfm carb, Weiand Stealth Intake manifold, no smog equipment, Hooker headers are in a box next to the car, and some true dual exhausts are gonna be fabricated soon, hopefully....
Old May 2, 2001 | 08:24 PM
82resto's Avatar
By the by.. they're the aluminum ones, (i don't know if there are iron ones, but whatever) if that helps
Jon
Old May 2, 2001 | 08:41 PM
ede's Avatar
ede
don't think your intake will bolt up, the chambers are larger than your bore, with a lot of cam the valves may hit the block, you can machine the block for clearance
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 2, 2001 | 09:01 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Those heads will work just fine with your 305. They have the dame 58cc chambers as the 305 heads, and all the vette L98 heads used the 86' and earlier intake bolt pattern, so you are ok there.
As far as perfomance, they are quite a bit better than the stock 305 heads, and do respond well to mild porting and gasket matching. Just don't port them out too much, the 305 needs high velocity, small ports.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
