Timing
Old Aug 26, 2004 | 10:22 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
Timing
its a pretty stock set up here. carbed 305, manual transmission.
what should i set my timing to?
I set it to 8, but when i plug the vacume advance in, it idles at like 2000 and wont go down. so im thinking 8 is probably a little too advanced.
can someone who knows please tell me? thanks.
Old Aug 27, 2004 | 06:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you're plugging the vac advance into the wrong place. There shouldn't be any vacuum on its port at idle, so plugging it in at idle isn't supposed to make any difference.
8° should be fine. Assuming of course that your timing marks are accurate.
Old Aug 27, 2004 | 06:03 PM
ummm. well can anyone tell me where to plug my vacume advance from? i got it going from the back of the carb, on the drivers side of it. Im not exactly sure if its right.
does anybody have a pic of it?
Old Aug 27, 2004 | 07:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of carb?
Old Sep 1, 2004 | 07:18 PM
rochester quadra jet
Old Sep 1, 2004 | 07:52 PM
nsimmons's Avatar
should be on the front bottom right, the back port is full vacuum, i have my gauge hooked to it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
