ignition problem
Old Aug 27, 2004 | 04:07 PM
Mr.W's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
ignition problem
Whenever I turn the key in the ignition half the time the engine doesnt crank, and theres a loud whirring noise. sometimes it takes several key turns to get the car to start, it usually only does this when it hasnt been running in a few hours (like in the morning before work). When I got my exaust done the guy heard it and said it sounded like a dead spot in the starter. Is this the problem? if so what do I need to fix it and how much will it cost.
Old Aug 27, 2004 | 04:16 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Yes, I had the same thing on my old V6 RS and it does nothing but progressively get worse. With mine, they put in a new starter and checked the flywheel for wear. After that, she started right up every time. Good Luck!
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
