Clatter (detonation) when starting
Old May 1, 2001 | 12:23 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
My car starts "instantly", but clatters loudly a couple of times just as it fires off. Why does it do this? What, if anything, should I change to stop this?
'87 IROC 5.7l TPI - original owner!
Old May 1, 2001 | 08:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure it's detonation/preignition, or maybe it's the lifters rattling?
Old May 1, 2001 | 08:30 PM
ede's Avatar
ede
i'd suspect lifters or oil preasure problems at start up and not detonation
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 2, 2001 | 09:25 AM
CloudIROCZ28's Avatar
It's part of the Ignition system....I brought my car over to a mechanic thinking that it's only the timing on the car and no big thing actually....It was a big thing.....Don't let your car die.....bring it to a mechanic now before internally the engines crank will get messed and a rod may break while your driving it's very serious the engine just may sieze right up....I would advize putting in a whole new block.....
IROC-Z
G92, LB9 305 TPI, 3.23
Old May 3, 2001 | 08:09 AM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
It's louder than lifters or anything like that. You ever heard an engine that's running on - dieseling? It sounds exactly like that, only very briefly (just a couple of "whacks") - instantly upon startup - just when the engine actually fires up.
This is a very low mileage engine (10K miles). I installed a GM crate engine (and swapped out cam and heads) last summer. Nothing needs to be replaced. I just have some kind of tuning problem.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
