F-Body Slimfast?
Old May 2, 2001 | 09:10 PM
dtbracing's Avatar
F-Body Slimfast?
My 85 Z is obese! I am told of 3200 lb f-bodies in street trim, is this true and how do I get there? Anybody mind sharing the weight of their car and how you got there.
Old May 2, 2001 | 09:25 PM
Vader's Avatar
DTB,
Give a yell out to the ODB. He's running VERY lean, but street-legal. I'll bet he can tell you where to shed 600-800 pounds.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 2, 2001 | 09:35 PM
Guest
Guest
Posts: n/a
See if you can search the old archives for Tim Burgess, he has a list that is so long you wouldnt believe it. It *may* be in the tech articles or somewhere over there. Complete list with weights and everything. I think he was around 3200 when he was done.
Old May 3, 2001 | 06:43 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
my car has a fiberglass hood, aluminum waterpump, heads, intake and radiator. The heater core and airconditioning equipment has been removed. The car with full interior weighed 3180. It had probably about 40 lbs of subframe connectors and aftermarket torque arm.
It started out as an 89 rs with no T tops and power windows/locks
Old May 3, 2001 | 01:38 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
My car with a quarter tank of gas, full stock interior, aluminum heads, water pump, and radiator, weighed 3350. Still have a/c and air pump. See sig for mods. That's without me of course.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
[This message has been edited by 3RDGENFRANK (edited May 03, 2001).]
gixxer92
Apr 12, 2022 12:09 AM
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
