Valve Seals Revealed!!!!
Old Aug 29, 2004 | 05:45 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
After getting sick of smoking, I decided to put seals on the ol' camaro. I learned...
-It takes at least 4-5 hours.
-I decided against putting seals on the exhaust valve, as this increases wear significantly.
-My motor already had positive seals on the intake valves, but they were brittle and worn.
-The exhaust side of the valve cover gasket was burnt to the point that it broke. The oil was forming a stalagtite of carbon on the valve cover.
But most importantly----IT DID NOT STOP THE SMOKING!!!
I am convinced that the oil is seeping down the exhaust valves into the exhaust, where it is burnt and creates the smoke. It does not smoke on start up. I am not taking the damn thing apart again, and will now live with the smoke, and tell myself that it is making the exhaust valves happy. :lala: since I know it is not being burnt in the combustion chambers.
I HIGHLY RECCOMMEND USING UMBRELLA SEALS on the exhaust valves.
Old Aug 29, 2004 | 06:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Valve Seals Revealed!!!!
Dunno about that.
Uh yeah. You always use positive seals (umbrella) on all 16.
Notes from my last set I did on an '88 LG4:
I used 2 intake sets by Fel-Pro to get 16 umbrellas.
Later, I checked at Napa and they listed individual positive-seal type exhaust seals and were cheaper than autozone.
The heads had pushrod guide slots, and the rockers were guided too. I did some reading on here and I'm not alone.
The engine I did them on was fouling plugs badly: see http://chevyefi.com/badplug.jpg
It stopped smoking at startup and at stoplights after I did them. I did all 16.
Old Aug 29, 2004 | 08:12 PM
REALPOWER's Avatar
Transmission: Th350
Re: Re: Valve Seals Revealed!!!!
Originally posted by jmd
Dunno about that.
Umbrella seals are not positive seals. The guide wear I am talking about is on the guide boss, not the pushrod guides.
Old Aug 29, 2004 | 09:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would suggest positives on both. Valve seals do not increase wear. Their job is simple. To prevent excessive amounts of oil from entering the combustion chamber.
if it doesn't smoke at startup, Why did you even bother with the valve seals? Valve seals only really smoke at startup, when the oil has enough time to seep down the valve stem. When the engine is running, the valve is moving up and down so fast, and the oil circulation is too rapid for oil to seep down. That being said, again, if it doesn'smoke at startup, I don't think it's the valve seals fault.
What is the "exhaust side" of the valve cover? The side that is on the manifold/header side? I doubt it's burnt. Try old and hard rather.
And no, umbrella seals are not positive. Umbrellas ride up and down the valve stem itself, positives are fixed around the guide boss. Umbrellas more or less deflect oil, positives act as an actual barrier.
Old Aug 29, 2004 | 09:56 PM
jmd's Avatar
jmd
Re: Re: Re: Valve Seals Revealed!!!!
thanks for the clarity; both of you. The ones I used are positives that stay secured around the boss and have multi-ridges around the valve stem.
so far, so good.
Old Aug 29, 2004 | 10:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I'm not realpower, but here it goes:
An umbrella seal controls the amount of oil the valve guide receives by deflecting oil splash away from the guide. Umbrella seals also move (up and down with the valve stem).
Positive seals are fixed (do not move) and provide a tigher fitting seal than the umbrellas. Their method of oil control is preventing it from running down the stem, rather than deflecting excess oil. Wait, I'm repeating myself....
A side note as to seals for exhaust versus intake: keep in mind, there are sever al different materials used in making valve seals. Basically, for exhaust, I only use Viton or Teflon. Anything else, really doesn't cut it.
*edit* This was in response you your question "define postive seals please" before you edited.
Old Aug 29, 2004 | 10:22 PM
jmd's Avatar
jmd
sorry about that. I read his post, then posted, then yours. I appreciate your time on this, since I didn't have the pos. vs. umbrella bit sorted out.
Old Aug 30, 2004 | 08:19 AM
REALPOWER's Avatar
Transmission: Th350
So what do you guys think? Since it no longer smokes on startup (it did before) but it smokes at idle after awhile, do you think it is oil seeping down the exhaust valve and getting into the exhaust and burning or do you think it is rings?
Old Aug 30, 2004 | 12:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I highly doubt any of the valve seals are in question here.
Do a leak down test. That will tell you the integrity (or lack thereof) of the rings.
Old Aug 30, 2004 | 01:53 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Like mentuioned in Steakmans post you should run a leak down test to make sure. New valve guide seals all around reguardless of what type will help alot especially since the exhaust side seals wear quicker then the intake side.
Old Aug 30, 2004 | 02:27 PM
jmd's Avatar
jmd
I am here to tell you, valve guide seals can do that, and you should do all 16, not just 8. My car doesn't smoke anymore and it used to smoke like a chimney.
Old Sep 2, 2004 | 11:13 AM
REALPOWER's Avatar
Transmission: Th350
Well, I am not inclined to do a leakdown test, because if it is the rings, I can't do anything about it. But I will say that I could hear air escaping on all 8 cylinders when I changed the valve seals. If worse comes to worse, I have a fresh motor sitting here.
Old Sep 2, 2004 | 01:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well a bit of air coming out is normal. The rings make the seal, its by no means perfect containment on either end.
Also should mention valve guides wear out too which most people on this board tend to forget and blame premature valve seal failure on crappy seals.
I would suggest you replace the exhaust side seals at a bare minimum and complete the job.
Old Sep 2, 2004 | 02:03 PM
REALPOWER's Avatar
Transmission: Th350
I believe that is what I will do when I get the time!!
Old Sep 2, 2004 | 02:33 PM
jmd's Avatar
jmd
SBC guides aren't a big problem. If you've got 60k on a set of seals and it's smoking on startup, it's the seals.
Old Sep 2, 2004 | 04:40 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
If it smokes after it has idled a bit, it's the rings. Do a leakdown! So what if you can't do anything about it, at least you will know for sure
Also, if your valve guides are really worn out, no seal in the world will stop oil from coming down around them for long.
Old Sep 2, 2004 | 04:42 PM
jmd's Avatar
jmd
Both the Gen I SBC and the Ford 4.6 will begin to smoke at idle with zero ring problems and bad valve guide seals. Burning engine oil has to come from someplace, but it doesn't have to be the rings in that case.
Old Sep 2, 2004 | 04:49 PM
406TPI's Avatar
Car: 1985 IROC-Z
I don't disagree with that, however in his case I do believe he has a ring issue.
Old Sep 5, 2004 | 06:05 PM
REALPOWER's Avatar
Transmission: Th350
I finished the job this weekend....and cleaned the heads a bit. Now it doesn't smoke a bit...although I worry about the guide longevity now. I also replaced the injectors, which cured the random misfire, although it seems to take a little longer to start now. Oh well, it runs pretty good!!!
thanks guys!
Old Sep 6, 2004 | 03:55 AM
joshwilson3's Avatar
Old Sep 6, 2004 | 08:06 AM
REALPOWER's Avatar
Transmission: Th350
Here are the ones I used. I like the rubber ones because they don't seal quite as well, which makes the guide lubricated better.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Sep 6, 2004 | 02:06 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Im removing my right head this weekend because i tried to stop the smoking and i changed the valve seals and i saw that one of the valves was slightly damaged. The smoking didnt stop so its probably a bad valve seat that causes it to smoke. I did a leak down test and that was just fine.
Old Sep 6, 2004 | 04:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
If you did a leakdown on that cylinder and it was fine then the seat is probably okay. What kind of damage did you see on the valve?
Old Sep 7, 2004 | 01:49 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
It looks like the valve had contact with something i saw it when i removed the valve seal.
Old Sep 8, 2004 | 07:36 PM
thirdbirds's Avatar
Car: 87gta 88notch 89 5spdgta 92 vert
Engine: 5.7
so with this all said. do you want to use positive locks on the exhaust ? anyone tell me wich 1 is the right one for the exhaust ? felpro-ss10058 felpro-ss72877 have 72527 for the intake, just would like to know which ones are best for exhaust. going to replace them asap. thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
dbrochard
Sep 19, 2015 08:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
tgp1990
Sep 4, 2015 06:24 AM
