TPI timing?
Car: 89 IrocZ
Engine: L98-ish
You need to locate the EST bypass connector, a single wire connector (forget the color coding), on my car it's located behind the pass. side strut tower..
Anyway, start the car (warmed up to operating temp in closed loop) and disconnect the EST line.
Adjust the sitributor CW or CCW to get 6* BTDC (stock setting), then tighten the hold down, shut the car off, reconnect the EST line.
If you reconnect the line prior to shutting the car off, the SE light will stay on.
Good luck.
Good luck.
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i wrote a fairly decent tech article on my website regarding this issue...
the links to the articles are here: www.IROC-Z.org/tech
there is a distributor install article and a timing article..
good luck
if you have any questions you can email me at: admin@IROC-Z.org
Webmaster: www.IROC-Z.org
good luck
Iroc8t8
May 4, 2026 08:09 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
