Mini Ram II on a 406......
Old May 3, 2001 | 10:21 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I may be getting a 90 IROC soon, and since the TPI is already on there (dont have to go through the trouble of swapping one in, yea!), what kind of power do you think is attainable with the following combo:
406, Forged pistons (not sure what brand, fill in if you want)
Forged Scat Crank
Splayed 4-bolt Mains
AFR 220 Heads
And this!
A Mini Ram II!
http://www.tpis.com/pg9-12.html
I am not sure what cam I would be able to run, never thought about doing this before. Any suggestions. Thanks guys!
[This message has been edited by Scott_92RS (edited May 03, 2001).]
Old May 4, 2001 | 07:26 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
try and find something in the range of 230-235 duration at 050 on intake and at least 550 lift. The only potential problem I see is that the miniram is sized for about a 195 cc intake port. You will have a gasket mismatch and I don't think matching the intake will fix it.
Old May 4, 2001 | 08:14 AM
Scott_92RS's Avatar
Car: 1992 RS
I guess I could save a few bucks and get teh 195cc heads.. The enegine most likely wont see anything much greater than 6000 rpm, where the 220cc heads would kick in.
Old May 4, 2001 | 09:17 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Talk to TPIS, I do believe that they do have a larger version now for 220cc heads.
Linson
Oct 24, 2025 02:00 PM
cowansauto
Apr 3, 2025 12:51 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
09ave
Sep 7, 2015 06:03 PM
