serpintine pulley set
Old May 3, 2001 | 01:08 PM
shutch's Avatar
i need to convert to serp pulleys on my '87 350 so i can go ahead with the procharger. is everything simple bolt-on (dumb ques). also, someone suggested where to get the hardware off the net, but i lost it. any suggestions? lastly, i've removed the air conditioner stuff; how will i know what size of belt to get or do i need to reinstall everything? tia...
Old May 3, 2001 | 08:39 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
I got my setup off an 89 305 at the local junkyard. About $150 for all the brackets, bolts, pulleys, and accessories(ps pump, alt.). To run the serpentine setup without a/c I think you will need an a/c delete pulley. There should be a tech article in the tech section about how to route the belt and which belt to use with no smog pump. Of course you will need the proper water pump like an Edelbrock 8881.
Old May 3, 2001 | 11:54 PM
John Boy's Avatar
www.tacreationsusa.com has a setup for ya for $200 bux everything you need...but the shipping will eat you up cause everything together(2boxes) weighs about 100lbs. I got it and everything went pretty smooth had to buy a connector for the alternator and I'm still looking for a connector for the A/C
Old May 4, 2001 | 12:01 AM
idrag2's Avatar
Instead of getting a A\C delete pully you can get a idler pully off of a 3.8 and drill a hole into the top of your A\C bracket and run the belt over it.
I DRAG 2
Old May 4, 2001 | 09:18 AM
Mark W. Winning's Avatar
<font face="Verdana, Arial" size="2">Originally posted by John Boy:
www.tacreationsusa.com has a setup for ya for $200 bux everything you need...but the shipping will eat you up cause everything together(2boxes) weighs about 100lbs. I got it and everything went pretty smooth had to buy a connector for the alternator and I'm still looking for a connector for the A/C</font>
The tacreations stuff works great. John, give them another call, they have the a/c line too.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old May 4, 2001 | 09:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
How hard would it be to convert my factory 83 v-belt setup to serpentine? Doesnt the tacreations kit need a reverse flow water pump? Will a reverse flow pump work with a SBC400?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
