washer pump not working
Old Sep 1, 2004 | 06:54 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
I switched my steering cloumn and had to make a few changes to the wiring of the wiper switch, but now my sprayers dont work.....is there a way to switch the wires to make them work like i did for the column..???? when i press the spray button the pupm goes click click.....like ti wants to spray...YES THERE IS FLUID
thankyou
Old Sep 20, 2004 | 12:45 PM
Car: 1987 Z28
bump, its been a while and im getting it safteyd in 1 week so PLEASE HELP ME
Old Sep 20, 2004 | 01:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it goes "click click" when you push the button, then it's working; as far as the switch goes, anyway. If the switch wasn't working, it wouldn't go "click click".
These pumps are an incredibly stupid design, that doesn't last for more than 5 years. The plastic they make some of the parts out of, dissolves in wiper solvent. In fact, in my 83, it died in 86. I blew off the factory stupidity and put in one like they went to in later years, that's a little vane pump or something, that squirts continuously as long as you hold the button down; and I liked that so much, I went and got the later model wiper arms, that have the squirters in the arms and sort of drop the fluid in an arc all across the windshield, instead of firing a jet of it at the windshield from a distance. Seems like the pump was just a universal replacement one from Auto Zone or Advance or some such, and the arms were like $12 the pair for used ones. Altogether better than even a perfectly working instance of the 83 stuff, and likely to last many more years besides.
Old Sep 20, 2004 | 04:56 PM
Car: 1987 Z28
i just need to get it working for a while so i dont really wanna spend to much
Old Sep 20, 2004 | 10:13 PM
Car: 1987 Z28
bump
Old Sep 21, 2004 | 11:23 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I'm betting that the pump died, pre-88 thirdgens got the "in the wiper motor" pump while the 88-up thirdgens got the "in-tank" pump. Just go get a new washer pump, I heard its $16. If you really wanna eliminate the worries, go to the junkyard and pick up a tank and pump from an 88-up car and wire it to your car.
Old Sep 29, 2004 | 10:08 PM
Car: 1987 Z28
still no luck people please help
Old Oct 1, 2004 | 06:20 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
is the rubber hose hooked up to it?
Old Oct 1, 2004 | 06:44 PM
Car: 1987 Z28
kay dude im not retarded
but yeah i figured out now i have to have my wipers on high and then hit the spray, i cant just hit spray, so i guess thats good enough
......thanx guys
Old Oct 1, 2004 | 06:52 PM
2 dope's Avatar
Engine: 305 LG4
I wasn't implying you were. Anyhow, they should spray without your wipers even being switched to the on position. Reason i asked about the hose is coz on mine, there was a small green and whitre plastic valve that the hose wasn't connected to and they wouldn't spray, but after i hooked the hose up they worked fine.
mustangman65_79
Apr 14, 2017 05:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
