Virtual Dyno
Old May 4, 2001 | 01:26 AM
johnyIROC's Avatar
Virtual Dyno
I just downloaded "Stock Plus V1.1" by Engin Pro Software. I thought it was pretty good until I tried to run a required HP based on estimated ET.
The stupid program is telling me that I will need 397 HP to run a 20 second 1/4 mile. This is based on the following info:
Weight: 3400 lbs
Peak HP: 5500 RPM
Peak Torque: 4500 RPM
Tire Size: 27"
Gears: 3.42
Am I doing something wrong or does this program just suck?
Old May 4, 2001 | 01:36 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
27" TIRES???
Old May 4, 2001 | 01:37 AM
jaretz28's Avatar
For some reason the demo did not work for me either. But I almost bought a used one of eBay. It was the full blown version. I was reluctant to purchase it because I go the same wacky HP and 1/4 mile times you obviously did.
I have bought DeskTop Dyno just for fun and I love it. Also out now is some Drag racing dyno software too. I have not found one comparable to the above mentioned. If you are serious about racing it is worth the investment.
Old May 4, 2001 | 01:46 AM
johnyIROC's Avatar
How much is DeskTop Dyno? Does anyone want to give me a pirated copy?
Old May 4, 2001 | 05:05 AM
Yarnboy's Avatar
Yea..I had simiar things happen..it also took a huge dump when I clicked certain buttons..I think ******* Bob took a C++ course and tried to make a program..I need like 1200hp and 976lbs of torque to beat a honda
  • Red '88 IROC 5 Speed 305 TPI w/3.08
  • Dual Friction Stage III Centerforce Clutch
  • Accel 300+ Racing Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Hypertech Chip
  • Hypertech Airfoil
  • Gutted Air Box
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old May 4, 2001 | 11:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by johnyIROC:
How much is DeskTop Dyno? Does anyone want to give me a pirated copy?</font>
Its $40 or less from Jegs, or check its homepage, http://www.motionsoftware.com/ Its well worth the price.
Piracy is a no-no. Please dont discuss it on Dirk's boards.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
