Rebuilding heads simple directions
Old Sep 1, 2004 | 11:45 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Anybody have good simple directions on rebuilding my heads. I have trickflows, i ported them and had a competition valve job done, i want to put them back together. links, sites or articles, thanks
Old Sep 2, 2004 | 02:08 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Insert valve
Install valve seal, caution, valve stem edges can be sharp, be careful, use a dab of oil and slowly install.
Install spring cup/locator
Install spring and place retainer on top
Compress springs and install locks
Slowly release the spring and ensure the lock sits correctly
Repeat 15 more times.
Its pretty much straight forward...
Old Sep 2, 2004 | 04:43 AM
ede's Avatar
ede
migth want to add check/shim for install height on springs. smack the valve with a soft hammer after assembly to set things or make them fly apart. i use b&s valve guide lube on stems and seats, wear surgon gloves has lead in it.
Old Sep 2, 2004 | 04:57 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I remember when I was in high school when my dad told me to do that after installing everything. I didn't see the purpose of it at the time.....that is until I had a set of keepers that weren't on good!!
Old Sep 2, 2004 | 10:18 AM
Car: 1987 GTA
what about lapping compound ? also, don't you install the valve seals after you check the springs and everything. Does anyone have complete step by step to check it all and do it right? also what about shims, how do you check the heights?
Old Sep 2, 2004 | 09:49 PM
RICHRAD's Avatar
yes , lap the valve to the seats first, each one a few times...then clean up the mess...
Old Sep 3, 2004 | 08:40 AM
Car: 1987 GTA
okay, so does anyone have this whole process all written up, maybe can someone scan it from a book or something? or a web-link? thanks-
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
hokis
Aug 9, 2015 03:57 PM
