AC recharge q's
Old May 4, 2001 | 11:20 AM
Remondi2's Avatar
AC recharge q's
What costs and procedures would be done on a ac compresor swap? I know nothing about ac but I figure most of the cost other than the compresor itself will be to recharge the system. Can I do this at home, if so how much would it cost and what would I need?
thanks
Old May 4, 2001 | 12:08 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Depends on if you have R12, or R134a. Check the label on the radiator support, and it will tell you. R12 is no longer available over the couter (unless, you have a license...) You will also need to be able to evacuate the system, (gotta vacuum pump), and recharge (got the manifold guages?) Look for an inexpensive garage to recharge for you. You can change the compressor, but, after that, ya need some special tools.
Old May 4, 2001 | 12:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
let the old Freon out by hand. Just wear gloves and buy the 134A recharge/convert kit usually about 30 bucks. Follow direction and wham its done. Not that hard at all.
Old May 4, 2001 | 03:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Even if you were to let the freon out (illegally) into the atmosphere, wouldn't you still need to evacuate the system?
Or is evacuation only needed if (A) the system's been leaking or (B) the fittings were opened?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 7, 2001 | 10:56 PM
speedlvr's Avatar
I put Freeze12 in my RS. It's not R12 or R134. It blends perfectly with R12 and is just as cold. R134 sucks. I have R134 in my IROC and wish like hell I knew about Freeze12 a year ago. I bought it at a local autoparts store.
Johnoooooo
Sep 22, 2015 08:55 AM
Formula_88AE
Sep 3, 2015 01:47 PM
hayesaw0210
Aug 23, 2015 11:15 PM
jackhammer
Aug 15, 2015 10:04 PM
Zachattack0925
Aug 12, 2015 09:52 PM
