Two ways to port plenum which is better?
Old May 7, 2001 | 02:02 PM
BrianB's Avatar
I have already grinded the egr walls down. But I did not get any type of performance gain. I have seen where they have ported it out so that the TB is just one big hole. They do this by removing the piece that splits the air up in the TB opening. I am still running the stock TB, will I see any difference in doing this, and is it safe?
Old May 7, 2001 | 06:44 PM
Vader's Avatar
Brian,
You may actually induce some turbulence directly behind the TB by removing the entire opening. For an overview, check this file:
Plenum Porting.pdf
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 8, 2001 | 10:58 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I agree w/ Vader. When i opened mine up, i blended the openings back as well as i could to provide as smooth a transitin as possible. Thats what it's all about.
Think about it. By removing that divider entirely, you haven't opened any extra area up for flow. You have only increased the plenum volume by some negliogible amount, but now ehn the air leaves the back of the TB it breaks up on the sharp edges and reduces flow.
As to why you didn't see any gains, well depends on the year/engine/tranny. If you have a peanut cammed stock 305, i wouldn't doubt you don't see much. I don't really notice mine that much really. Other factors can play in too, like maybe you're running lean and opening it up more has leaned it even more. I'm running bumped FP and i'm still on the lean side.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
MantyZ28
16
Dec 21, 2015 11:02 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
mx127
Aug 10, 2015 08:13 AM
