broke off
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
broke off
I was taking the CTS sensor out and the freaken top broke off
so I got mad and put the vice grips on it and now the nut part is completly off and all I have left is about 1/3 inch of the treads sticking out. I put the vice on the treads and cant get a good bite to get it out. What do I do now???? 9 dollar part and she sits till I can get the old one out. I am thinking about dynomite
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Could slot the remainder of the threaded portion and use a chisle or something similar to try and turn it, making sure to soak it for a bit in a penitrating lube before hand. Since its a pipe fitting those are tapered threads so theyre going to be in there pretty good. As a last resort you could always drill and tap the intake to 1/2 in. NPT threads and use a 3/8 to 1/2 in. fitting.
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally posted by RB83L69
If it's in the water outlet, just go to the parts store and get a new one of those... they're like $5.
If it is in the intake, use a cripple torch (propane) to heat up the aluminum around the fitting (don't melt a hole in it), and use an E.Z. out. If that doesn't get it, then get a drill index and drill it out one size at a time untill you can possibly split what is left of the fitting with a chisle and peel it out of there with a needle nose pliers, then chase the threads with a tap.
We have to do this a lot at work because of the constant clean-up every night. Can't keep the water out of the machines or electrical cabinets. The acids and water will eat the peckerhead off a motor in 3-4 months.
Car: 88 Camaro SC
Engine: SFI'd 350
Is it in the intake, or the water outlet?
Some sort of extractor might work. The fitting is 3/8 NPT but I dont know what the ID of the sensor housing is.
Pac J
May 17, 2020 10:44 AM
sjorgens
Oct 1, 2015 07:54 PM
