Do I have a Rear Main Seal Leak?
Old May 7, 2001 | 04:57 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I noticed some oil dripping down on my y-pipe today, does this mean I have a rear main seal leak. I just got this gm goodwrench 350 about two months ago, thankfully there is a warranty on it. By the way can a dealer ship put ceramic coating on headers.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old May 7, 2001 | 05:05 PM
Stoopalini's Avatar
Before you assume it's the rear main, check your valve cover gaskets 1st.
My full size blazer (350) and my camaro (305) have both had this problem and it was the valve gaskets. they tend to leak in the back when they get loose, and drip down making you think it's the rear main.
Just something to check out.....
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- centerforge clutch/3.08 geared rear
1.6 Roller Rockers and Cam / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip
Headers - Cat Back system - Flow Master - dual chrome tips
adjustable Coni shocks & struts
Old May 7, 2001 | 05:54 PM
Car: 99 Formula
Axle/Gears: 342
Wow, thanks, I checked behind the valve covers and I got some oil on my fingers, I retightned the wind nuts and I ran the car and turned it off and didn't notice any oil dripping down. My car as of a couple days ago started running rough at idle and when I gave it gas, now that I tightned the valve covers it cleared up, was I loosing compression or is there another reason for this?
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Old May 7, 2001 | 08:53 PM
SUPER-SPORT-CHEVY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
</font>
Compression is made in the combustion chambers not the block. The only reason i can think of for a rough running engine that was cured by a valve cover adjustment is the pcv valve had incorect pressure and was bouncing around. Must have been some oil leak for this to happen.
SSC
Old May 8, 2001 | 04:46 PM
Stoopalini's Avatar
Hey, your welcome! Been there -- done that
You could have been loosing power from oil seeping down into the rear spark plugs. You might want to change them out if it looks like it was.
Also, like SS Chevy said, the PVC system could have been getting incorrect readings due to your crank case pressure being off. But it shouldn't have been too far off.
Actually, now that I think about it, the oil collecting on the Y-Pipe will heat that pipe up A LOT! your O2 sensor may have been freaking out from the added temperature?
Thomas.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
