drain cock fell inside radiator..
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
drain **** fell inside radiator..
Today i replaced my drain ****, but the piece inside the rad fell inside it.. is this going to be a problem? I just dont wanna start it up before i know if this is an issue or not.. the old piece was really soft and cruddy so, its not "hard and new".. should i try and get it out?? it looks impossible without taking the whole radiator out.. any ideas?? thanks
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah definatly get it out of there
do as RB said and go in thru where the bottom hose is and try there if its located close to it if not then take out the radiator and shake it out
Transmission: 4L80E/4L80E
Drain ****, driver's side.
Lower hose, passenger side.
Not seeing how removing the lower hose is going to get to it.
Remove radiator, shake piece out of upper hose nipple - maybe.
Do nothing - viable.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't know about yours five7kid, but the drain **** is on the passenger side on my 89 Iroc and I 'm pretty that's where it is on the 88 Iroc's
Spent too much time under the hood of FWD GMs lately, I guess.Let me try again (after having actually gone out and looked this time):
The tranny cooler is going to get in the way of the petcock and lower hose nipple (I think - without having removed the hose to look).
KO1
16
Oct 15, 2015 05:00 PM
raymondandretti
Sep 27, 2015 06:43 PM
