Backfire when advanceing timeing?
Old May 8, 2001 | 10:13 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
When i advanced timeing to 8 deg BTDC, it back fired from the exhaust! I'm not for sure at what RPM though... If i had to guess i would think 2K. My fuel pressure is at 46 - 48 PSI. Did i maybe do something wrong? I unplugged the ecm wire for the timeing (EST i think its called). Bumped timeing to 8 deg. Then before i reconnected the wire connector, i revved it.....What could cause such a thing to happen?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 9, 2001 | 12:30 AM
Jester's Avatar
Backfiring can be a sign of overadvanced timing, but not till it gets alot more than 8 degrees. What was it set at before you changed it?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 9, 2001 | 08:48 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
6 deg BTDC
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 9, 2001 | 09:06 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A backfire through the exhaust is more correctly called an afterfire...and it is a sign of unburnt fuel continuing combustion in the exhaust. Withe the EST connector off you are not getting full timing, therefore, you're not getting really complete combustion, thus when you revved it some of that unburnt fuel continued to pop in the exhaust.
Normal and nothing to worrry about.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 9, 2001 | 09:08 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I had a similar problem after I swapped intakes....in my case my timing was way RETARDED.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 9, 2001 | 09:22 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
gotcha Ed, thats the kinda reassurance i wanted.
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
