What does detonation sound like?
Old May 8, 2001 | 09:58 PM
KW87GTA's Avatar
I have been asking some questions about timing, cause I would like to get mine set to the best I can, some have said to bring it to the point it detonates and back it off two degrees, but I don't know what this sounds like. I have an 87 L98 TPI and I know stock it was 6* I currently have it set at 10 and don't appear to have any problems, I would like to advance it as much as possible before detonation though, help. Thanks.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old May 9, 2001 | 12:33 AM
Jester's Avatar
Stick a couple small rocks in a coffee can, wrap it in a blanket, and shake it. Thats what it sounds like. It can be quiet and hard to discern, When test driving roll the windows up, and turn off everything you can.
Also remember that the "3 rocks in a coffe can" is major detonation, you might not be able to hear minor. so it's a good idea to retard the timing a degree or 2 after you stop hearing anything.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 9, 2001 | 10:32 AM
greearhr's Avatar
If you have a knock sensor you may never hear the detonation as the computer will retard timing before you can hear it.
Bear Tracks
Old May 9, 2001 | 02:05 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Bear tracks hit it...unless you bypass teh knock sensor your computer will most likely back off the timing before you hear anything.
How to bypass the KS...real easy, go to radio shack and buy yourself 3.9k ohm resistors and hook it between the senor connector and ground. Then you can check for detonation w/ different timing.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
