The BIG Thump?
Old May 9, 2001 | 12:48 PM
SpeedStar's Avatar
The BIG Thump?
Does anyone have any ideas what could be making the thumping noise in my 91 Z when I hit the gas. I think it is probably the tranny moount has gone or possibly broken a motor mount. It just started yesterday and all I've had time to check is my U-Joints which are fine. Any suggestions would be helpful. Thanks.
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar383/Team_Speedstar
Old May 9, 2001 | 01:48 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you hear a thump when you floor it from the stop, your tranny mount is broken. It's so common in these cars that further diagnosis is pointless.
...ed
btw, if you could check the u-joints, how could you not check the tranny mount. All you had to do was push up?
Old May 9, 2001 | 02:00 PM
SpeedStar's Avatar
I know I only looked at the tranny mount. It looks in bad shape. I am going to put the car on jack stands and unbolt the mount bolts and jack on the tranny to see if the mount seperates or not. I probably should have checked that when I had it up in the first place. (DUH!)
Thanks for the reply.
http://www.geocities.com/speedstar38...Speedstar.html
Old May 9, 2001 | 04:57 PM
Ed Maher's Avatar
Car: 04 GTO
Just to add, get an energy suspension poly unit, it has a metal interlock so that no matter how far it stretches it can't actually physically seperate.
Also, in the meantime until you get it fixed, take it easy on it. With the tranny flopping around like that you are subjecting your u joints to some torture.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 9, 2001 | 06:07 PM
SpeedStar's Avatar
Yeah I have been. When it started I went directly home and parked it, and when I do drive it its under the speed limit with as little gas as possible, so I don't hear it knockin on my tunnel.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
