I need some help
Old May 8, 2001 | 09:33 PM
cobrakiller1989's Avatar
I need some help
I have a new radiator, good coolant level, and my fans work fine. When im driving around town in 80* and hotter weather my car runs fine, right around 200-210*. But, I could be driving down the highway in the same weather and even cooler weather and my car will get very hot, like around 240*. Why is this? The only other things i can think of is that my thermostat is sticking or my water pump(fairly new) is bad. thanks for your help.
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
Old May 8, 2001 | 10:29 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is the upper radiator hose collapsing??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited May 08, 2001).]
Old May 9, 2001 | 12:00 PM
This may sound dumb, but If the problem only occurs when im on the highway (between 2250-2750 rpm) how can i tell if the hose i collapsing? Or what is a good way to test for this? thanks again
*1989 RS
*355 CID
*Richmond 3.73
Old May 9, 2001 | 12:17 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
have a trans cooler? the trans might be getting hot at higher speeds.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old May 9, 2001 | 12:22 PM
Yes, i do have a trans cooler, but i know im probably making a bit more heat anyway because my speedo cable broke and now my torque converter isnt locking up as it should because the VSS isnt working. could this be making my engine run about 30* hotter when it should be running cooler?
Old May 9, 2001 | 06:11 PM
Jimmy_CFH's Avatar
My camaro does about the same thing. It seems to heat up when I'm barely on the throttle, or just maintaning speed. My guess was that the carb was leaning out on me, or the cc q-jet was mucking up the timing on me. I can hear the fan kick on, but it's about 30 degrees hotter than normal. It hasn't overheated YET.
