codes 13 & 44
Old Sep 10, 2004 | 01:50 AM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
codes 13 & 44
Can anyone help me out here. I got codes 13 & 44 flashing up on my 85 pontiac transam, 305 v8, which I know means oxygen sensor signal lean etc.
Does this mean I need to replace the oxygen sensor? Car has been running really lumpy lately?
Thanks.
Old Sep 10, 2004 | 06:56 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Code 13 means ECM is not recieving a signal from the oxygen sensor, so it could have possibly become unplugged or the wire might have melted on the exhaust manifold.
Check it to see what's up. I'd change it out if it's overdue anyway.
Old Sep 13, 2004 | 11:46 PM
Car: 85 Transam
I had a look at the harness. Everything checks out ok. Me thinks the sensor has given up.
Old Sep 14, 2004 | 12:32 AM
bobsroc's Avatar
Car: 1987 IROCZ
Could be the sensor or it needs cleaned or it could be your motor is running lean. What is the fuel pressure like? Fuel filter? Injectors? Does the car run hotter than usual? Do the plugs look like it is running lean? Don't bet the farm until you check a few things.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
