new VATS lock cylinder installed
Old May 9, 2001 | 01:02 AM
Eightyninef's Avatar
yepper.... I spend 1/2 day installing the new vats lock cylinder. what a
Royal PITA ! Taking the steering column apart is nothing compared to
snaking the wires down the column. I only recommend doing this job if
you have patience, otherwise it can be frustrating. Then my horn
didn't work and I had to pull the sterring wheel again, sheesssssss.
I'm happy though as I don't have to worry about my baby getting ripped
off.
Larry
once stranded by VATS, but now with VATS back to life
Old May 9, 2001 | 06:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When I replace the VATS cylinder, I cut the wires at the cylinder (if they aren't broken already) and tape the new wires to the old, then pull them down through the column. Very easy, just be gentle, don't want to ruin the new wires. I'm glad to see you kept the VATS, it may just save your car someday.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 9, 2001 | 08:48 PM
I tried do that, but the wire connector was to big to go down the column. I had to remove the wires from the connector, then pull them through. then reinsert the wires into the connector. not having the tool to remove the wires from the connector was the biggest problem.
Larry
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
