ODB, question on TFS heads.>>>>>>
Old May 10, 2001 | 09:20 AM
Polecat's Avatar
Thanks for the followup on my question in the carb section about your Trick Flow heads on your 383. But why do you like the performance but say they are a pain in the ****? I may soon be swapping over to aluminum heads to help on my compression some, and was considering them. But not if they are not worth the $900.
Thanks in advance for anyone's input.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old May 10, 2001 | 03:21 PM
The ODB's Avatar
they are worth $900 for sure.
The inline valve heads shouldn't be any more problem than any other aluminum head,
but the twisted wedge or canted valve heads are a pain to work with.
Fly cutting pistons, setting up different length pushrods for intake & exhaust for proper valvetrain geometry, and helicoiling all the bolt/plug holes.... just some of the issues you'll have to deal with.
As far as function & power once they are all set up, they work great. The TFS street heads are a great high velocity port design that does NOT require a long duration camshaft to make big power numbers. That means great drivability and great top end performance as well.
Old May 10, 2001 | 03:59 PM
Polecat's Avatar
Thanks! So they Trick Flow 23 degree heads in Summit, pat # TFS-30400002 would work without modifications?
If so, that may be worth the $925.
MoJoe
Sep 24, 2015 09:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Keith5
Aug 27, 2015 04:37 PM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
