vacuum can
Old Sep 13, 2004 | 01:20 PM
darksyde's Avatar
Car: 1988 firebird formula
Engine: 5.7
Transmission: auto
vacuum can
i recently purchased a 1988 firebird formula ,the car originally came with a tbi 5.0 .it was switched to a 5.7 ,retaining the tbi. the car runs well but it sometime knocks under hard throttle setting off the service engine light.i ran the codes and came up with codes 43 and 45 .i have recently replaced the oxygen sensor .now i only get a code 43 .ive tried adjusting the timing but to no avail ......any suggestions?.....also while looking over the engine compartment i came across a round canister mounted under the driver side fender towards the front of the car .it has vacuumm lines coming out of it but not connected to anything.the car to my knowledge has no vacuum leaks.any thoughts as to where this would go connected ?....thank
Old Sep 13, 2004 | 01:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Thats the charcoal can. It takes in vapors from the fuel tank. When the engine is running, it sucks those vapors back through the intake system for combustion. So yes, there is vacuum involved with it, but no, it is not a vacuum reserve canister.
Code 43 is the TPS.
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
That's the basics. Make sure you pull the voltage first.
Old Sep 13, 2004 | 02:03 PM
darksyde's Avatar
Engine: 5.7
Transmission: auto
vacuum can
the charcoal can is hooked up .what im refering to is round and a little bigger than a softball. its mounted under the driver side headlight.
(i saw it there while replacing the headlight motor).......thanks for your input
Old Sep 13, 2004 | 03:06 PM
bobsroc's Avatar
Car: 1987 IROCZ
As stated above, the softball looking thing, under drivers side front fender is apart of the charcoal canister setup. I am sure of it because I took all that junk off yesterday and routed the fuel tank vent directly to the TB.
Old Sep 13, 2004 | 03:12 PM
darksyde's Avatar
Engine: 5.7
Transmission: auto
OOOOOO....Got it!.......thanks
Old Sep 13, 2004 | 03:40 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
That is the vacuum canister, not charcoal canister. It keeps a supply of vacuum for the heater/AC/defroster vacuum controlled distribution system. I don't think it's connected or tied into the charcoal canister at all.
Old Sep 13, 2004 | 07:53 PM
bobsroc's Avatar
Car: 1987 IROCZ
Since mine is gone now, maybe someone can actually look under the car and trace the vacuum lines to see for sure, now that is a thought.
Old Sep 13, 2004 | 08:22 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
That round plastic ball holds vacuum for the cruise control. It has nothing to do with the emissions system, or EVAP.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
